Originally posted by Thudpucker
Rick, you get a couple Nurses over and Wayne will fall right into line behind them. He's used to that!
That's all I need Thud, the miss's to catch us in the boat shed with two nurses! Knowing my luck though they'd both be twin Nurse Wratchets!
Anywho, it really wasn't much of a winter but still seemed to take forever to end. Spring is here but it's still a lil' too frosty (+2 deg C) to do any epoxy work. So I puttered around the shed figuring and planning next steps etc.
What we're looking at here is the upper bulwarks of the hull. It's a separate part that gets glued onto the hull. Stations on the frames locate it properly. I ran into a little issue with a fairly large gap developing when I lined up the ends of the panels.
The gap was about 3/8" and much to big to just fill with goop. I started at the ends, which were easiest to properly locate on the hull and worked my way into the middle. The gap got bigger as things tightened up. I cut a few kerfs to relieve some of the stress and used screws & washers to hold it in place.
No gap now! When it warms up these will get glued into place permanently.
Looking around I figured it was time to dryfit the bow thruster and get it lined up so the tube can be glued and taped into place.
I seem to remember reading somewhere that thruster props are typically serviced from the port side. It was only through pure luck that I got the holes cut in the right place so my thruster prop can be serviced on the port side! I had to scratch my head a few times 'cause I'm working upside down on this thing so port is starboard and starboard is port! *lol*
That's it for now. Hopefully it'll be a lot warmer next week and we can get some epoxy & fiberglass work done.
