GeorgeKohler
- Feb 3, 2015
- 33821
- 159
Hi All,
Mercruiser 5.0L carb'd Bravo III. Two seasons ago, I replaced the starter because it was turning very slowly even with two fully charged brand new batteries. After the starter replacement, it turned over perfectly for a year.
Beginning late last season, after spending an hour or so on the hook for lunch, I'd turn on the blower for 4-5 minutes and then turn the key. All the electronics would power up, warning beeper would sound, but then NOTHING when I turned the key to start. I mean nothing. Not even a solenoid click. I opened the engine hatch, checked some battery/starter cables (all were pretty tight and didn't seem corroded), tapped on the starter a few times, turned the key back and forth a few dozen times, still nothing. Then, all of a sudden, it turns over, nice a fast like I've got two fully charged brand new batteries and a brand new starter. This has happened 5 or 6 times on the water now.
I can't seem to make it happen in the driveway. Turns over 100 times out of 100. I think it has to do with the heat building up in the engine compartment, and then cooling off with me tinkering under the hatch. I don't think my wiggling cables or tapping the starter has anything to do with getting it to start.
Could it be a bad key switch? Bad slave solenoid? Bad solenoid on the starter? Corroded/loose cable somewhere?
