The black screw should be the idle. Turn it in to gently seat, and then two turns out (not 2 1/2. The main jet is 2 1/2 out)). The ADS only affects "run ability", not mixture. The choke is adjustable to more (rich) or less choke. Should be open when warm, closed on start. There is "hunting" without any load. With a new carb your mixtue screws should already be set this way.
