What is the running temperature? Mine has an ECM because it is fuel injected and the Low CO model with a catalytic converter. It has been very touchy since the day it was installed. Before it had 5 hours on it I needed the software flashed, then before 50 hours fuel pumps needed replacement. It hasn't been as bad on plugs as many people say but even when it works perfectly when I shut it down correctly it will start alarming when there is nothing wrong with it. To silence it I have to treat the remote as if I am preping the generator to start again. After 3 days the remote loses it's data connection to the generator and I need to cycle the start/stop/auto switch on the generator itself to regain control from the remote.I was told from Kohler that is a safety that totally kills power to the remote and the ECM on the generator so the genset's battery will not discharge. I'm also told if I wire 2 pins at the genset to my old breaker panel momentary start switch I could reestablish communications with the remote without having to open the ER and hit the switch on the generator. Since the boat is always plugged or being charged via solar and ACR's I wish the timer could be disabled. It's one of the quirks I haven't had the need or desire to resolve.
