Originally posted by Billylll
I'm not sure the mounting is the same between the KVH M1 and R1.
A note to all users KVH or Intellian that use Dish Networks sat at 61.5 degree there are changes that need to be done to still receive this bird. I believe the frequency has changed. You should get a notification from KVH or Dish Networks about this. If anyone needs the KVH notice here is a link about the changes that must be made.
KVH Technical Bulletin: DISH Network Changes to 61.5°W Satellite
Products Affected: TracVision M1DX, M3DX, M5, M7, M9
DISH Network® recently changed the tracking parameters of its 61.5°W satellite. Since TracVision® antennas use these parameters to identify and track the satellite, the antenna may no longer be able to track 61.5°W.
As a result of this change by DISH Network, customers who wish to receive programming from the 61.5°W satellite will need to implement the following modification depending on the antenna type:
TracVision M1DX or M3DX: The satellite tracking parameters must be modified by entering antenna commands using the Flash Update Wizard* as follows:
Connect your laptop to the TracVision antenna’s main board and turn on the system.*
Enter the commands listed below into the Wizard’s “Command Line” box:
HALT
(at)DEBUGON
(at)SATCONFIG,61W,12987,20000,78,0x1002,L,U,3
ZAP
* Please refer to the Flash Update Wizard’s Help file for details.
Note: Once the software modification is complete, the interface box will report a tracking frequency of 12412
The complete Technical Bulletin s available on the KVH Partner Portal. Download the bulletin now or log in to the Partner Portal any time to access it.
When I have substituted the (at) symbol for the
real at symbol that this board messes up.
