Got up to the boat last weekend for more trouble shooting. I'm starting to think the problem may be a bad resister wire to the coil. From searching I found the wire should have 1.8-2.0 ohms mine was 4.0 ohms.
So after running for one hour at the dock at around 2000rpms I shut the motor down. Would not restart, then I thought I should hurry up and switch the coil out for the one on the port motor. Fired right up, this is what has me thinking the coil is overheating due to bad resister wire.
I'm not sure how much work replacing the resister is. This has me thinking about splicing a new wire on the boat side of the harness and running this to the + side of the coil. And installing a coil with built in resistance.
Al
Al
