Each motor has its own battery and a house battery. I have Yandina combiner that connects all three batterys for charging.
Ground from each motor to its battery, in addition all three batteries are ground together.
Al
Al
Originally posted by Sandy
So you don't have the engines starting and running connected to separate P & S batteries?
Are all the battery negative terminals properly connected together and then the daisy chain connected to clean and tight engine grounds on both engines? There can be a several important engine grounds on each engine.
Some alternators will not start charging until a critical engine RPM is exceeded.
The fact you don't get steady flashes from the timing strobe is certainly not good if the strobe had very good connections.
