Originally posted by alk
Any more details on the boat, does it have isolation transformer ( probably not), galvanic isolator (maybe), polarity indicator ( probably), generator, water heater?
Do you have an ohm meter? Most likely something on board is leaking neutral to ground, which is not a good thing, but not in itself a disaster. Combine it with poor neutral connection to the legit ground, it could become a disaster. With you boat NOT plugged into shore power but the shore power cord plugged to your boat, the generator switch ( if so equipped) set to shore power, and all A/C breakers turned on - put one lead from your ohm meter on the neutral prong of the shore cord, and one one the ground prong. If you aren't showing on open circuit - infinite ohms, or near to it, you have a neutral to ground leak on board. I did this exercise years ago, and had many - water heater, defective 120/12 combination interior lights, and believe it or not light bulb that previous owner wired as polarity indicator on the panel. No wonder I showed 120 volts from the prop shaft to the ground, and got zapped every time i climbed onto the boat. Luckily I never killed anyone swimming near the boat when had shore power turned on.
Nigel Calder's book 'Boatowners Mechanical and Electrical Manual' was priceless in finding my leaks. Most critical is that A/C ground is tied to DC ground, and A/C neutral is not tied to A/C ground ( unless set to generator).
