I have an older 3227. Its all white.
I have had an absolutely terrible time trying to get the hull back to par.
I know my standard is higher thqn others, but nonetheless I have been frustrated.
It was a very clean boat when purchased, actually whiter than others of the same era. I believe it was cleaned with an agressive cleaner on a regular basis. It has clouds in the gelcoat that even wet sanding does not remove. I have used Wizards, Finesse, Diamond luster, maguires, and finally after all of that, the buff majic was used last. It worked good at "blending" the surface together. It does not carry the gloss that finesse does, but overall it presents itself better.
I have owned many boats from new to used as well as wheeled for some time as a business. I recommend trying as many different products as possible. remember the more times you go over it, the better it will look!
Good luck
