survey costs
CaptCrunch
I was reccomended by someone to a surveyour in Florida to do the survey on the Donzi. 32ft boat, twin i/o with geenrator. was told hull and engine survey is $1,000 does that soudn high or right on target?
Depends on what they are doing.
I paid $14 a foot, but mine was weak.
I was also in NC wherever everything seems cheaper!
Who is the surveyor? Stay away from the guy I used.
surveyour was reccomended by a mechanic my marina knows very well in florida. I spoke to Arlen Leiner AAC Marine Group
Currentsea, what do you mean by weak survey?
He basically looked at everything.
I found more things wrong than he did.
He did the tapping of hull and moisture checks, that is key.
He didn't do much with motors like check motor mounts.
I have seen a few surveys and they all have varying degrees of thouroghness.
As boaters, we know more than the surveyors sometimes.
If your a new boater then its well worth it.
I tested everything on my new boat personally.
I know the boat well, so I know where everything is, what does what, and how things work.
My only issue was noone actually checked my motors or IPS drives but fluids looked good, boat ran and handled like a charm, and is still in warranty, so what was my risk!
Like I said before on a older boat, I would have a mechanic pull motors apart. Check manifolds, fluids, mounts, etc. That is the big bucks. A/C, heat, water heater, fridge, bilge pumps, you can do. Hull, have it moisture checked and sounded out. So a weak cheap survey with an expensive mechanic by hour is way I would go on a older boat out of warranty.
Many a good expensive survey has resulted in expensive repairs. Ask anyone here. They miss things.
You stated that the price included engine survey? What does this include? Oil survey, compression check,transmission? Generally when a boat survey is done this does not include engines and generator. If it does than that is an excellent price! In Michigan a survey runs about $15 per foot and does not include mechanicals.
Chris
