- Jan 3, 2013
- 33144
- 1,490
Do you made a blog about the 1997 Trojan 440 express?
Originally posted by jmeirhofer
Yes I started one but admittedly hav not had time to keep it up recently
Well I did one hatch today. While I am not happy with the stain on the edging I used, it did not come out half bad. I will sand the stain off and try a different color. I just laid some pieces around it to see how it is going to look. It is the one behind the stairs so not really readily visible. What I really do not like is the way it breaks up the flow of the wood. To that extent I have decided to leave the outboard hatches sealed up and not use them. I will still have the two small ones in the galley and guest SR and the large one in the middle of the saloon to get at the holding tank plumbing. Tomorrow I should be finished with the underlayment.
Well the second try at staining was a bit better. I may only be a few shades difference but it blends a whole lot better. I also finished all of the underlayment today. Next weekends goal will be to finish the other three hatches and prepare the rest of the floor to lay the new flooring in. A few more weekends and this project should be complete.
It is the space under the stairs. It is where the access to the water tank discharge is. Here is a picture of the whole area.
The layout with out the third stateroom is significantly different. Plus with the stairs and door frame removed there is not a lot to go on in the other picture.
Lol hogan. I have stuff stuffed everywhere. There is so much stuff in the master SR that the bow is about on inch lower in the water.
