Originally posted by bobalong
So what have we determined here ? Are spin on, marine fuel filters adequate water separators or not ? Is the only REAL separator the kind with a drain on the bottom ? If water is so detrimental in gasoline engines with a carburetor why did they dribble water from a coke bottle down the throat while revving the motor to clean carbon deposits (recommended back in the day) with a benefit & no damage. Many of us have accidentally had water intrusion from different goof's when fueling. I left the cap off of my filler for months in winter 08. Mixed some fuel conditioner in a gallon can of gas and poured it into the tank, oops, forgot to replace the cap. I know some snow and rain found it's way into the system. Never had an issue. Only separator is my spin on type. I have gone thru thousands of gallons of gas in the last few years. Might be time for a new filter & a spare.
Water in diesel fuel ? Now there's a catastrophe waiting to happen. Compression is much higher, 14:1 - 18:1 and higher, compared to gas of about 10:1.
I might add that as far as I know there hasn't been any fuels with ethanol or methanol in my tanks. In fact around the lakes, gas stations advertise non alcohol fuels for a few cents more per gallon.
Speaking of fuels. It has been my experience that today's fuel's (of marginal quality) have a longer life before degrading, in the winter than in the summer. There's an experiment for somebody next summer. two quarts of the same gas, one in the refrigerator, one not. How long before separation ? OR , two quarts of gas, one stored with my favorite, SeaFoam and the other with Stabil. At the end of the summer are they both still good ? That's all I got. Carry on.
Ayuh,.... A canister type fuel filter,
IS a water separating filter,
by Design...
Fuel, whether gasoline, or diesel comes in at the top of the filter, 'n leaves the housing, again, at the top...
Water, falls to the bottom of the filter, because of gravity...
Water is Heavier than either fuel...
The petcock at the bottom of some filters, is to test for water, not so much to remove it...
If yer gettin' that much water, the element needs Changin', not just draining..
'n if ya look long enough, 'n hard enough, Yes, Wix builds filters, With drains, that fit the standard filter housings found on All of the typical motors we use, Merc, Volvo, OMC, Crusaders, etc...
But on most factory installations, there usually ain't room enough, below the filter canister...
You can also find various Sized filters to fit the standard housings,...
1 pint, to 1 quart..
Pouring water down through the carb's throat to de-carbonize the cylinders is Completely irrelevant to this discussion,...
The water goes directly to the combustion chambers, 'n nowhere near the fuel delivery system, other than straight through the carb's throat...
Water in the fuel, leads to detonation in gasoline motors, 'n to a lack of power in a diesel motors, because water displaces the fuel, 'n water don't burn...
Compression ratios are also irrelevant...
Water in the fuel, leads to corrosion in the fuel delivery system, which causes
Way more problems than the water itself...
