- Feb 17, 2003
- 11160
- 121
If you have the 10 micron water separating filter, you are in luck. There is a Racor accessory which fits below their filter that allows you to drain any accumulated moisture without changing the entire filter. (as typical it takes an 11/16" box end wrench to loosen it; bastard size!) So, you can either have the water separating filter alone or the same filter with the drainable bowl beneath it.
